Full Version: Moi3d to Enscape
25 Nov 2021   [#1]
Hi Moi'ers
Been away for some while and wonder if it would be possible to run Enscape with Moi?
* Michael for Nobel Prize *
25 Nov 2021   [#2] In reply to [#1]
Hi Stardust, I'm not familiar with Enscape, but my guess would be that you could probably export out from MoI to an .obj file and then import that into Enscape.
26 Nov 2021   [#3]
As Enscape works directly with Revit, SketchUp, Rhino, ArchiCAD & Vectorworks
I suppose you can export also from Moi in 3DM, SKP...3DS, DXF...
(not tested because I have not Enscape! :)
In other side Only the file formats; *.gltf, *.obj or *.fbx can be imported to the Custom Asset Library of Escape
so FBX can be used ;)
But...if it is possible to import models with a file format of OBJ, FBX, and GLTF. It is recommended that you import low polygon models with less than 20,000 triangles !
