I've just installed MoI on my new laptop.
What folders and files should I copy from my desktop PC to have the same settings and shortcuts on the other computer?
W 10 on both.
Marek
Hi Marek, your settings and shortcut key definitions are stored in the moi.ini file, so you'll need to copy that file over to your new computer to transfer settings.
You can find the moi.ini file by typing Win+R to bring up the Windows "Run" dialog, and then put in:
%AppData%\Moi
That will open up the MoI appdata folder where moi.ini is stored. Copy the moi.ini file over to the equivalent spot on your new computer, in place of the default moi.ini file that will have been created there.
