Show messages: All
1-4
5-8
Hi Chris,
re: return to original tabs - press Win + R to bring up the the Windows "Run" dialog and put in:
%AppData%\Moi
That's the MoI app data folder. Inside there go down into the startup folder and remove the file named DeathPane.js , that's the one that is modifying the side pane tabs.
Its in the instructions, also read the instructions at:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=10465.1
The "Roaming folder" is your:
C:\Users\"YOUR user name"\AppData\Roaming\ as it is for all Win apps...
There you will find the "Moi Backup-YOURUSERNAME" Folder, it's your original setup.
Just delete the Moi folder there and rename the "Moi Backup-YOURUSERNAME" folder to "Moi" and you're back to your original...
Please read through all the stuff on the link above, any further questions, please post them there...
So I got frustrated and just deleted Moi4 and then reinstalled it.
BUT... I didn't have to reenter my serial number and the layout is still dorked. The main screen is the default color, the tools pane is ok, but the objects/type pane is still up, and all of the "extras" are still along the bottom.
Thoughts?
Chris
[url=https://postimg.cc/SjYJ2Kpk][img]https://i.postimg.cc/SjYJ2Kpk/2022-01-13-01-18-25-Greenshot.png[/img][/url]
Hi Michael. This helped me find the data that was still controlling the UI, even after the fresh install. Everything is now working properly.
Chris
Show messages: All
1-4
5-8
