Full Version: Copy
While Copy - is it possible to change the selection from the default source object to the copied one?
Marek
Hi Marek,
> While Copy - is there possible to change the selection from the default source object to the copied one?
It's possible by modifying the Copy.js command script. I've attached a version of it that will behave like that.
Copy.js
Can you put an image before after of the use of this new "copy" ?
Hi PIlou,
before:
after:
Yes, this is great!
I've got used to this behavior working for years with ArchiCAD, so it is more natural to me.
Thanks a lot.
Marek
Ah ok! So the result of Copy are ready for a copy itselve or any other functions!
The old version was ready only from the original !
Am I right ? :)
Hi Pilou, yes the new version selects the newly created objects.
Cool! :)
