Show messages: All
1-8
9-10
Hi morph3us,
> I refrained from using your obj export algorithm, because in my opinion the weighting is off.
> As you can see at arrow 2, big shapes are very lowpoly, while the small air vent holes on the backside are way too smooth already.
You can use the "Divide larger than" option in the meshing options dialog to help with that. You can put in a distance value there and that will make any polygons larger than that size to be further refined. Use the arrow in the lower left corner of the meshing options dialog to expand it to get more options.
You can use that option to generate more uniformly diced up pieces like in this example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
> I dont know what the difference is between exporting all meshes at once to
> exporting one on its own, but yeah, there it is.
There is no difference that I am aware of, maybe there is some difference on the receiving end.
> Still... My reasoning towards the OBJ export algorithm stands and there still seems to
> be a problem somewhere in this file... :(
> Is there any data log where I could have a peek?
It sounds like you're not making use of the export options to generate the type of mesh result you want. But it's hard for me to tell for sure since I can't reproduce anything that you're doing over here.
Sorry no there isn't any data log specific to STEP export.
File e-mailed now Thanks
Show messages: All
1-8
9-10
