I imported a pdf file with curves.
When I zoom on it, Moi has a strange behavior.
Some curves are shown as line when a part of this curve is not in the frame.
The curve (as object) stays a curve but is shown as line.
Perhaps a problem with calculation.
serpentin.3dm
It does happen on my computer also...
If you move the indicated point just a bit it fixes itself...
I assume that's because the points are parallel with each other (top to bottom, or left to right)?
Hi Phiro, some more info on this curve display glitch here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7590.3
