Show messages: All
1-10
11-13
Thank you.
The imported box does not change the shape of an egg. What's wrong with the code?
After I use three shortcut keys, the fault appears
Q: script:moi.geometryDatabase.saveAs( 'c:\\test.obj', 'NoUI=true;Angle=180;Output=quads' );script:moi.geometryDatabase.deleteAll();script:moi.geometryDatabase.fileImportSubD( 'c:\\test.obj' );
A: script:moi.geometryDatabase.saveAs( 'c:\\test.obj', 'NoUI=true;Angle=180;Output=quads' );
Z: _ImportObj c:\test.obj
Hi feirui445,
Do you mean you're pressing these 3 keys in sequence or are you using just the first one which already does an combined export and reimport?
Your 3rd key has:
The _ImportObj plug-in brings in polygons as planar faces in MoI, it does not apply sub-d smoothing. If you want to use the native MoI sub-d converter use this instead for your importing step:
script: moi.geometryDatabase.fileImportSubD( 'c:\\test.obj' );
Another thing which may be a problem is that by default Windows restricts programs from writing to the root c:\ directory so you might need to run MoI with administrator privileges for it to be able to write to that location.
Show messages: All
1-10
11-13
