Show messages: All
1-8
9-19
Wow!
Didn't know that, so useful!
Here is a faux Cage edit method, for those that want to point push.
This is a simplistic 2d - 1 axis limited at a time - method...
VIDEO
Thanks, might come handy!
Yep !
That is the same than enable history of the Flow! ;)
One can, on more complex solids, also use the "edit frame". And all that we can do with it : resizing and rotating, partially or over the entire surface of the projection plane, etc.. Great!
I ask myself a question, can we have a regular grid? This is not the case in my example (I have to try).
Zooen
""""Can we have a regular grid"""""
If you create your desired rectangle then run "network", should give you your "regular grid"
You can also manipulate the point count and loft to create various grids
BurrMan > If you create your desired rectangle then run "network", should give you your "regular grid"
can you show me an example ?
http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=675.6
You can also use Extrude with the "Set path" option to make a point grid surface:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
Thank's Michael that suits me!
Zooen,
Yup, I was wrong. Michael gave the answer.
doesn't matter! Either way, even the best can be wrong.
Zooen
Show messages: All
1-8
9-19
