Show messages: All
1-13
14-19
""""Can we have a regular grid"""""
If you create your desired rectangle then run "network", should give you your "regular grid"
You can also manipulate the point count and loft to create various grids
BurrMan > If you create your desired rectangle then run "network", should give you your "regular grid"
can you show me an example ?
http://moi3d.com/forum/messages.php?webtag=MOI_FRANCAIS&msg=675.6
You can also use Extrude with the "Set path" option to make a point grid surface:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
Thank's Michael that suits me!
Zooen,
Yup, I was wrong. Michael gave the answer.
doesn't matter! Either way, even the best can be wrong.
Zooen
Show messages: All
1-13
14-19
