hello my friends,
doe's someone know if it is possible to remove some selected points from a surface?
I can add points, but i cannot delete them.
if i press DEL, the complete surface is gone.
Hi BlackBird, sorry no there isn't any function for removing points from a surface. Point editing on NURBS surfaces has some limitations because a NURBS surface is inherently structured as a grid made up of rows and columns, you can't just insert or delete a single point out of it.
If you're doing surface control point manipulation you might want to look at sub-d modeling, it is a lot less restrictive about it.
Seems we can delete any point(s) selected of curves who create a surface ! ;)
