Show messages: All
1
2-7
There is one for the free prog (or Pro) of Subdivision : Rocket 3F
https://rocket3f.com
Here the 2 ShortCuts from Moi to Rocket 3F (will be given in Loading Rocket 3F
Send_to_Rocket_3F hard
Send_to_Rocket_3F Sub
Hi Ed, yes it is possible to do a script that uses predefined meshing parameters. Check out here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1723.10
Perfect Michael - I'll check it out.
Michael -
I got two scripts working based on your forum reference - one for saving a low poly OBJ, and one for saving a high poly OBJ.
However the scripts save every object on the screen. Is there a way to save only the objects I've selected prior to running a script?
Hi Ed, yes you can call moi.geometryDatabase.
fileExport() instead of moi.geometryDatabase.saveAs(), it will write only the selected objects out. It takes the same parameters as saveAs().
That works perfectly. This will save a lot of time. Thanks for the awesome support Michael!
Show messages: All
1
2-7
