Show messages: All
1
2-5
Hi Chris, "ZoomApproachTarget" means it will move by a fraction of the distance to the rotation pivot point like how mouse zooming works.
Is it the zoom speed only that you're having trouble with? You might try setting Options > View > 3D View projection = "Parallel" since zooming in a parallel projection view is much simpler than in a perspective view.
What do you mean by the "1.0 parameters", are you editing the speeds in the moi.ini file directly? If so then MoI v4 uses new settings in there:
RotationSpeed
V4=1.0
PanSpeed
V4=1.0
the settings under:
PanSpeed=1.0
ZoomSpeed=1.0
are not used by MoI v4 anymore so there won't be any effect from setting those ones.
You can use the UI under Options > View > Rotate/Pan/Zoom options > 3Dconnexion options > "Pan speed" and "Zoom speed" which should set the right ones.
The new settings are used in v4 because the default speed was changed in MoI v4 and so the speeds set for previous MoI versions are ignored and new ones used instead.
Ok, that clears it up a bit. Was sure that those 3d connexion settings inside moi wouldnt have any effect on the actual speed.
The zoomapproach is still not really clear what the difference is but hey :D
Sry for the unnessecary thread!
Hi Chris, re: zoom approach target, the "approach target" means something like this, the eye moves forward some fraction of the distance between the eye point and the target point so it goes closer and closer to it but doesn't go past it unless you're really close to it:
Non-zoom approach target means the both the camera and target point move together forward like this:
This only applies to a perpsective view, in a parallel view zooming is different and is controlled by a scale factor value instead of needing to move the eye point around like is needed in perspective.
Oh wow thx alot!
Show messages: All
1
2-5
