Full Version: Text
Show messages: All
1
2-3
Hi RayCAD, I'm not sure if I understand correctly but I think you want to make "Annotation text" in MoI rather than model geometry text.
To do that, do not use the Draw solid > Text command which generates the text as model geometry.
Instead use the other Text command in the Dim tab here, this will be the same kind of text object that you'll get from DXF import:
Dear Micheal,
Thank you so much. I didn't notice that there is a command already there.
Again, thank you so much for your support.
Show messages: All
1
2-3
