Full Version: Text
Dear all,
How can I create a whole text together but not a close curve.
I explain, to be like Annotation Text like the one Autocad creates.
Because if I want to change the word to another word I need to change it the whole sentence not individual like close curve.
With Autocad I done it and then exported to 3D Moi as a format DXF and when I click on the text to change the properties
3D Moi gave me the chance to edit the whole word but with the 3D moi itself you couldn't.
Any suggestions please or exist a script that covers this problem.
Thank you so much for your help.
Hi RayCAD, I'm not sure if I understand correctly but I think you want to make "Annotation text" in MoI rather than model geometry text.
To do that, do not use the Draw solid > Text command which generates the text as model geometry.
Instead use the other Text command in the Dim tab here, this will be the same kind of text object that you'll get from DXF import:
Dear Micheal,
Thank you so much. I didn't notice that there is a command already there.
Again, thank you so much for your support.
