Full Version: Lag
20-39
40-44
Will do and thanks so much for your help!
Hey Michael,
I started using the beta of v5 yesterday and I haven't had the lag once so far. I dont know what changed under the hood, but its working like v3 now. So whatever you did. Thank you!
-B
Hi Billabong, that's great! Yes I tuned up Extrude so that it should be back behaving like V3 now.
quote:
So for v5 the Windows version will support Direct3D11 (default), Direct3D9 and also OpenGL.
Will WebGL be available for the Web-kit on V5? And maybe a newer version of Javascript?
Thank you,
Wayne
Hi Wayne,
Sorry no both of those are the same as v4 and will likely be that way for quite a while yet.
The Direct3D11 / Direct3D9 / OpenGL support that is mentioned in the quote there is referring to the 3D viewport display engine which is not HTML based.
20-39
40-44
