Full Version: Lag
13-32
33-44
Hi Billa, I've got a Direct3D9 version ready for you to try, I've sent you a PM.
Hey bong, so the setting talked about before is titled "opengl rendering gpu". Select your gpu in the dropdown for that setting... under power management mode, is there a "performance" option instead of power optimization?
The last thing is regarding ykur monitor with the gtx card. Are you sure your monitor is "g-sync" compatible? Look at the monitor technology setting listed there....
So I selected my card in the drop for Opengl rendering gpu and selected maximum performance. See attached. Not sure if my monitor does allow for G-sync, but the Nvidia settings has it turned on. In other news Michael sent me the Direct 3d9 version this morning and its running great. Everything works except for Zoom. I have a delay with it, but i had a slight delay with in, v3. So At least the lag is gone.... for now (Fingers crossed, for good). Thanks Michael!
and thanks Burrman for helping as well. I'm still down for troubleshooting if you want to continue, if not. I understand. Here is a link to my main monitor.
https://www.newegg.com/aoc-q3279vwfd8-32-qhd/p/N82E16824160392?Item=9SIA6ZP8TJ6088
So looming at AOC display website, it appears you can "setup" g-sync to be enabled...
Main thing, is that monitor plugged into a display port or one of the other types...
Is it set as the "primary" monitor?
You could disable all the g-sync for that monitor as a test. So on the g-sync tab and also in the monitor technology option of the 3d settings, all in nvidia driver....
Be sure to remove moi from the windows display control. Actually, i believe windows should have notified you that nvidia already had control... (but i could be wrong)
Its plugged using display port and is set as primary monitor. I disabled G-sync. And I released Moi from windows display control last night. No change on the delay.
The Direct3D9 renderer was successful in getting V3 behavior on this hardware. So for v5 that will be an option you can set in moi.ini under GraphicsAPI=Direct3D9.
So for v5 the Windows version will support Direct3D11 (default), Direct3D9 and also OpenGL.
Hey Bong,
I don't really have anything else. Michaels solution is well enough anyway...
Be sure to put any of those changes back as they were before...
Will do and thanks so much for your help!
Hey Michael,
I started using the beta of v5 yesterday and I haven't had the lag once so far. I dont know what changed under the hood, but its working like v3 now. So whatever you did. Thank you!
-B
Hi Billabong, that's great! Yes I tuned up Extrude so that it should be back behaving like V3 now.
Will WebGL be available for the Web-kit on V5? And maybe a newer version of Javascript?
Thank you,
Wayne
Hi Wayne,
Sorry no both of those are the same as v4 and will likely be that way for quite a while yet.
The Direct3D11 / Direct3D9 / OpenGL support that is mentioned in the quote there is referring to the 3D viewport display engine which is not HTML based.
13-32
33-44
