15-34
35-54
55-74
75-94
95-99
Ok, now when going to the forum with a browser on a mobile device it should automatically redirect to the mobile forum version.
The new mobile version is a huge improvement, thanks!! (I’m viewing with iOS 14)
--Larry
On a Samsung Galaxy Tab S6, (android software), ~10 inch tall big screen, both forum text,
and images, look great in either portrait or landscape orientation. Some larger screens shots need a bit of scrolling, which is fine.
On an android based cell phone, the text fits the screen perfectly.
Thank you Michael.
-Brian
In mobile version, I don't see how to access the french Forum.
Don't know if it was the same before.
Regards,
Here on Samsung A50 mobile version works fine. Is it possible to auto resize imagines to the screen, avoiding scrolling?
Is there any way to have my mobile device use the regular, full forum as opposed to the mobile version?
Hi Burr, yes add mobile=0 at the end of the address, like:
http://moi3d.com/forum/index.php?mobile=0
Then that should not redirect to the mobile version. I'll see about making a setting for that.
Like a charm!!
Side note. Just before i switched back, the mobile version didn't have a "guest" access.... it wouldn't view or show unless i logged in...
Could be just me though...
Image resizing implemented for mobile version.
Added iframe resizing so embedded videos will fit within available space like images do.
Hi Michael :)
Iframe embedded video Youtube resize ok
Image resizing give a distorted result,don't keep original aspect ratio
screenshot from my mobile
here a weird result:first image distorted,second not
No problem Michael if it involve too much work to solve this problem,i can return to web version
M
Added "Lang" dropdown on top right for mobile to nav to different language forums.
Hi Mauro,
Thanks, it's probably because your images have a width and height given in the img tag instead of those being blank.
Shouldn't be difficult for me to fix it to make those work ok.
Hi Mauro, I think the image sizing should be fixed now. It was broken in the regular forum before it's just that it would previously not resize it unless it was over1024 pixels in width .
It's ok :) !
Now it's a pleasure to read the forum with mobile version
Thanks !
Your Monreal was in reality a Fiat! :D
Mobile version updated - back arrow in header to nav back to threads list.
hi michael,
everything is looking great. i tried the mobile site again and only had one problem. it didn't seem to show the updated posts the way that the desktop site does.
Hi
The mobile update is great! One thing I miss compared to the desktop version - within a string of messages, the "show messages" groupings are only at the bottom of the messages when you've scrolled right the way down to them, not at top and bottom like the desktop version. As I am frequently reading the Forum on a mobile where I can't remain logged into the forum, seeing the latest messages of a string I've been following takes longer to get to than using the desktop option. Perhaps you could consider adding it in?
As someone who has been using MoI3D since before the V1.0 release, it still remains by far the most intuitive, and remarkably powerful, CAD package. At the time I needed something easy to use that had the option of STL output. I was hooked straight away! I applaud those who come up with scripts, Nodes etc., but to be honest I've never really needed more than the default install, That said, the addition in V4 of dimensions has removed a step normally done in another package. As its been so long since you got some money from me for the V3 Update to the V2 Update to V1.0, I bought a complete new licence, and will do an upgrade to the old licence as well. I've used MoI3D for modelling multiple different things - sci-fi armoured vehicles and aircraft, several sheds/stores/workshops that have then been built, 3D printed badges, plans for building refurbishments and many many more. Keep up the good work, and maintaining your original design goals.
Andrew
Thanks Andrew, I am so happy that MoI has been useful for you!
I will see about adding the "Show messages" links at the top for mobile like the desktop version, it should not be difficult to bring it over.
15-34
35-54
55-74
75-94
95-99
