19-38
39-58
59-78
79-98
99-118
119-138
519-529
I don't have time to provide drawings, but here is a quick summary: There are two systems of projection, for representing a 3D object in 2D; generally called the "British system" and the "American system". They are both "standards". They are both 'logical', in how they work. What is not very 'logical' is this: Assume the "Front view" is the front view of a car. In the British system, the left view will show the left side of the car. In the American system, the left view will show the right side of the car! I was taught the American system and used that until I left aerospace in 1998. So I feel safe in saying that the Brits got it right and the Yanks should have left well enough alone. You can adhere to a standard, but you have to decide which standard! Life is complicated. (For anyone who wants more info on the two systems, I am referring to 'The Motor Vehicle', by Newton, Steeds, and Garrett, tenth edition, 742 pages, Chapter One: 'Engineering Drawings'.)
What about creating MatchSrf in MoI3d? Would it be useful for MoI users. I know that is possible same thing with blend but MatchSrf could also be useful.
I`ll keep my finger crossed also for analysis tools (curvature graph, zebra, check continuity on curves and surfaces). I know it`s much but I think it`s a right thread to dream ;)
One "fairly basic" thing I would like to see in MoI is converting points on a curve between sharp corners and smooth curve points. Full on spline curves with tangent handles like in 2D drawing softwares would be great too.
Don't know if it's a reasonable or sufficiently popular ask; of course it's merely an ask:
SVG output.
Certainly there are a bevy of 2D vector apps, but MOI is exquisite, accurate, and handy.
If, not... I am happy continuing to paste 2D curves into Affinity Designer.
Fillets without limits (it`s 123design still available to download and test for free here:
https://web.archive.org/web/20170202170834/http://www.123dapp.com/design ):
What is the N° version of this 123D ?
I have version installed 123D_Design_R2.2_WIN64_2.2.14 and the fillet engine is very robust.
Sorry, I`ve repaired my link
same number for me :)
Same for me too... 2.2.14
Too bad that autodesk stop the 123D products.
They were simple and easy to use.
Now they push Fusion 360, more complex and more technical oriented.
Artistic design is not the target of Autodesk...
123D Design was a good tool to do complex filetting...
Would it be possible to have same filleting in MoI3d or it`s too hard to implement. 123D was based on many open source docs. I`ve wondered maybe if that filleting algorithms from 123Design are also published it would be possible to have same in MoI.
Hi mdesign, that particular area of 123D was not based on an open source library, it used Autodesk's proprietary Shape Manager geometry kernel. Shape Manager is a fork of the also proprietary ACIS geometry kernel (
https://en.wikipedia.org/wiki/ShapeManager).
So no it is not possible for it to be used in MoI. Autodesk does not license Shape Manager for use in non-Autodesk apps. ACIS is available to be licensed but it's pretty expensive, it's more oriented around higher cost "Enterprise" level software. It could be possible that MoI would use ACIS at some point but sort of as a last resort.
Robust filleting does not really come from implementing a single algorithm well, it's about recognizing and handling a lot of different kinds of special cases for different corner juncture conditions. It takes many many man-years of effort to produce a robust one.
Thanks, Michael. Understood.
My fillet companion for MoI is punchcad viacad...
Its the acis kernel for around 100.
I can do the filleting you show above, in that..
What version ? I see 200 to 700 $
https://www.punchcad.com/punch-v12-1-update-offer
Hello Michael,
Thank you for all that you do.
This is just a respectful reminder from message
10194.12.
Some method whereby one might set a formula to manipulate the Dimensions' Numeric Value.
Your wonderful software and support are legendary.
MindSet
Hey Frenchy,
""""""""""""What version ? """""""""""""""""""
Yup. $200. Hadn't looked in awhile and I'm on version 10. So back in version 10 you could get it for $99 when they were in ownership transition...
But $200 is still insanely cheap for the acis kernel and It's fillet ability.
So the difference would be, shapemanager is offering that realtime push pull of the fillet. A huge time saver if you are just randomly pushing fillets around all day to look at various result.
The viacad engine still needs a value entered, and will throw various errors when it hits limits, that you have to back out of, where the shapemanager just "stops", or presents a non destructive error) etc... (At least in Version 10. I don't have or haven't looked at the newer version since then)
But you still have to learn the shapemanager filleter too... It doesn't come without limitations.
BTW: The best filleter I have found over time is Spaceclaim. It's also the ACIS Kernel......
I have the free 123D and the Space Claim light DesignSparks Mechanical who have i believe the same kernel! ;)
I'd love to be able to have persistent construction lines that act like a subclass of regular lines. Yes, I can just have a specific style for construction lines, but this would be more convenient. Bonus points if construction lines are tied to the objects they reference and move with them. One could even posit preventing options that make the construction line's relation no longer true, allowing for at least some types of modeling constraints.
Notice the limit....
19-38
39-58
59-78
79-98
99-118
119-138
519-529
