Full Version: V5 Wish List
Show messages:  1-3  …  464-483  484-503  504-523  524-529
13 Jun 2023   [#524] In reply to [#523]
Hi Peer, unfortunately typographic points are not commonly used as a unit system in CAD software. So adding that would trigger some compatibility issues around data transfer.
13 Jun 2023   [#525] In reply to [#524]
Thanks for explaining Michael. Hadn't thought of that.
- Peer
16 Jun 2023   [#526]
Hey Michael,
Any chance to get transparency options (ie. translucency) for solids (and surfaces)?
I am needing to place objects into a hollow part and am finding it challenging.
MindSet
16 Jun 2023   [#527] In reply to [#526]
Hi MindSet,
What about checking the box under View that says "Display hidden lines"? That basically makes everything translucent like in the attached image.
If you're placing a shape that doesn't have many edges, like a sphere, you can select that shape and do Construct > Curve > Silhou to see its silhouette.
- Peer
16 Jun 2023   [#528] In reply to [#527]
Yo Peer,
Yep, that does seem to work in most instances and is sufficient in the current case.
Thanks!! You helped make this an even better day for me.
This community is as wonderful as the software itself.
I am very appreciative on both counts.
- MindSet
7 Mar   [#529]
I'd go in for a camera snap to ?ortho axis? in the 3D viewport when orbiting by holding down shiift, I find this a huge benefit/workflow enhancement in ZBrush.
// Rich
