Hello,
New user here.
Can I have a darker theme in V4? Can I load a V3 theme? I couldn't find a theme for V4.
Also, can I use V3 scripts in V4? Or everything must be new?
Tks,
Ulisses
Hi Ulisses, most v3 scripts can be used directly in v4. There were a small number that needed minor updates. The V4 script parser is stricter about syntax errors and will throw an error on invalid code while the script parser in v3 would silently ignore some of those things.
V3 customized UI files cannot be directly used on v4 but they can be adapted. Here's a recent one:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10095.9
Thank you,
I'd like to suggest a preference checkbox to enable Dark theme.
Ulisses
I second this. Each upgrade and beta, I spend to much time searching this forum for the latest Dark Theme install, notes, guide. It's a time suck
You have a very speedy way (for Windows) to have a "Dark Thema"! ;)
Key Logo Windows + "+"
= Enable Mode Color Invert
Key Logo Windows Logo + "ESC"
= Disable Mode Color Invert
My dark theme with V4.0
-Zooen
Hi Zooen,
Would you please post your theme files? I like your theme!
+1 to that, Zooen :-)
Hi, Lavellotron
You have to go see here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9242.1
and here :
https://moi3d.com/forum/index.php?webtag=MOI&msg=9138.1
and here :
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.13
I made quite a few modifications and used several scripts.
We should consult the various discussions in which I participated. Finally everything is here on the forum, and I can't upload all the folders, files and scripts.
It's always a satisfaction to personalize your interface by yourself, it's not very complicated and there will always be nice people to help you.
