Full Version: V4 released!
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-121  122-141  …  182-188
13 Jan 2021   [#62]
Congratulations Michael on the V4 release!
18 Jan 2021   [#63]
Hi, Michael.
In the Moi Wiki, the hotkeys section, it says:
1) On a scene browser color swatch, Ctrl+Shift+Left click will assign the selection to that style without altering the visibility or locked state of the objects to match the current style.
2) Clicking on the name part of a scene browser item is used for selection, if you hold down Ctrl while clicking on it it will work for deselection instead of selection,
and if you hold down Shift while clicking on it it will only select currently visible objects instead of selecting and showing all objects that belong to that slot.
Does not work. Or do I not understand something?
Beta version from December 21, 2020.
18 Jan 2021   [#64] In reply to [#63]
Hi WN, those are out of date, they applied to MoI version 2. The scene browser in MoI v2 did not have a selection dot indicator on the right-hand side of the scene browser item. Instead you could click the text to select or deselect. When the selection dot was added in v3 then selecting by clicking on the text was removed.
Also in version 2 if you clicked on a swatch where all the current objects assigned there were hidden, it would hide the objects. This behavior wasn't too good though and so that was changed in v3 as well to not alter the visibility state of objects when assigning to a style.
I'll update the wiki to remove those obsolete hotkeys.
18 Jan 2021   [#65] In reply to [#64]
Now everything is clear, thank you!
21 Jan 2021   [#66] In reply to [#65]
Hi
Does the old v3 scripts work also on v4?
Perttu
21 Jan 2021   [#67] In reply to [#66]
Hi Perttu,
Yes most of them do. A small number needed minor updates because the newer script engine in v4 will throw an error on invalid script code that was silently ignored in the old v3 version.
22 Jan 2021   [#68] In reply to [#67]
just one silly question ..
Can I still keep the version 3 on my computer
and use both if needed
Perttu
22 Jan 2021   [#69] In reply to [#68]
@ Pertu
Of course yes ! :)
...but it's very more powerful to launch many sessions of V4 in the same time!!!
(depending of your Hard memory available! ;)
22 Jan 2021   [#70] In reply to [#68]
Hi Perttu, yes MoI v3 and v4 can co-exist on the same machine.
You don't need to uninstall v3 when you get v4.
25 Jan 2021   [#71]
Hi, Michael.
The fillet tool does not work with this geometry.
Will there ever be a fix or always use a workaround?
1.3dm
Message 10083.72 was deleted
25 Jan 2021   [#73] In reply to [#1]
Hello Michael!
Life's too short...too many topics on this forum :)
Could you help me?
I bought the V4 some days ago but I'm in trouble with many scripts that worked for V3.
Is there a place (inside this forum) where I can easily get all the necessary infos to get V3 scripts easily working also with V4?
I hope so.
25 Jan 2021   [#74]
Try with an Arc Circle tangent without unity but not sure you can go to the end! :)
(then make a trim not shown here)
or with the function itself...but you must enter some very small number! :)
0.0000001
and i am not sure of what and where you want fillet something!
25 Jan 2021   [#75] In reply to [#73]
Hi Marco,
> Could you help me?
> I hope so.
Yes, this is the place right here. Just list which specific scripts you are having problems with and I will reply here with some information to help you.
Thanks, - Michael
25 Jan 2021   [#76] In reply to [#71]
Hi WN,
> Hi, Michael.
Actually no there will never be a fix that covers every single type of possible geometric shape because geometry comes in infinite varieties so it isn't possible to test every kind of shape. That's one of the things that makes this a difficult area for software.
But usually there are not a lot of problems in curve filleting compared to solids filleting.
In this case here it's related to the specific "anti-tangent" shape you've made.
For this particular bug a quick workaround is to use Edit > Separate and then select 2 separate curves at a time and do Fillet, followed by Edit > Join. That will avoid the bug in the corner processing for this case which I've added to my list to investigate fixing.
25 Jan 2021   [#77]
Also make sure that the script is the latest version.
I recollect that a few scripts were tweaked to be compatible during the early v4 beta periods...
25 Jan 2021   [#78] In reply to [#76]
Hi, Michael.
I asked about the corrections only for this case. Because I know that this is a pain for both you and us.
I follow this topic on the forum and try not to ask you tormenting and repetitive questions, but apparently I did not succeed.
Thank you for the proposed solution to the issue, as always, everything is surprisingly simple.
26 Jan 2021   [#79] In reply to [#75]
Ok Michael.
Thanks a lot!
Well...I've a bunch of scripts...but because right now I can't have enough spare time to devote to this task, I'm going to pospone my request.
Anyway, thanks for the help.
In the next weeks I hope I will start picking some V3 script to be fixed with your help.
See you next time :)
3 Feb 2021   [#80]
Hi, Michael.
Look at the file, it has a Loft for two figures.
I used a rectangle star and a Loft.
loft.3dm
3 Feb 2021   [#81] In reply to [#80]
Hi WN, it seems that there is a slightly different result with one surface malformed depending on the ordering of the profile selection.
In the one on the left if you click on the rectangle first and then click on the star and then do the loft, it generates an ok result. If you click on the star first and then the rectangle second then there is one piece that isn't formed properly.
But in general a loft between curves with a different number of segments with sharp corners will not make a very good result, it's usually better to loft between smaller pieces to control which curve segments will match together. Or split pieces up so that the curves you are lofting between have the same number of segments so they can be matched segment to segment.
So in your case, maybe a reasonable approach would be to set up connections like this:
Then split the rectangle up, and join the pieces together. Then with t here being the same number of segments in each curve they will match segment-to-segment giving this result:
loft_profiles_split.3dm
