4-23
24-29
Sorry when i click again on one edge before valid the Blend command
my surface disapears and calcul failled!
I must miss something! :)
Edit :) I must use the Add Sync Points!
But drawing on a same vertical! (And not on the vertical middle of the edges or vertical extremities! )
Validate (Enter or Right Click but not Done) then click click on the Edge... for cross uncross!
All that was not so evident! :)
Limited results here with parallel shelves.
Try rotating one of your shelf planes on an axis passing through its blending edge, before the blend.
No sync points.
Or rotate one shelf about its center... So the blending edges are not parallel, nor parallel in top view...
@ Bemfarmer ...you right that is infinite crossing with rotating the planes! :)
Else funny Blending!
Result is a solid after Join
The Big "blended corner" is just increasing the Bulge out of reasonable limit! :)
Hi Pilou, so it looks like in the particular symmetrical case you have there, the self-intersection in the twisted version confuses the blend construction mechanism.
If you move one of your planes a little bit then you should be able to click on an edge and make the twisted version.
So a little bug! ;)
Else effectly works if move or rotate :)
4-23
24-29
