Full Version: V4 beta Oct-27-2020 available now
Show messages:  1  2-21  22-41  42-61  62-81  82-101  …  142-158
28 Oct 2020   [#22]
Hi, Michael.
Exporting blocked lines to the PDF, as they are displayed in the program, will allow you to show the center lines.
There is also no control when measuring the radius inside the circle behind the center.
After fixing the radius dimension line, if the cursor remains in the same place,
then the extension line with the text is not fixed, only the arrow and the radius line remain on the screen.
dim.pdf
28 Oct 2020   [#23] In reply to [#22]
Hi WN,
Can you please describe this one a bit more? If you could also post the .3dm model file that may help me understand.
Yes this will happen if the 2nd and 3rd points are stacked up on top of each other. You can fix it by selecting the dim, using Edit > Show pts on it, and then dragging the last point so there is some distance between it and the previous point.
28 Oct 2020   [#24]
Good Job Michael !
Message 10011.25 was deleted
28 Oct 2020   [#26] In reply to [#1]
Hello Michael!
"This one is a big milestone because for the first time in 5 years my "todo" list of things for finishing up the v4 software is empty!"
So...a huge, long, and steep road you traveled!
Finally we're almost at a true new "starting point" now.
Congrats :)
I can't wait to see some new long awaited feature coming to Moi3D also :)
Stay well!
28 Oct 2020   [#27] In reply to [#20]
excellent job, as usual!
I dont't know why, but I cannot find in moi.ini 3dm settings: [3DM] Version=
Mik
28 Oct 2020   [#28] In reply to [#27]
Thanks Marco & everyone!
@Mik - re:
It should be near the end since it's a new setting, but also it will only get added when it has been accessed at least one time which happens when you save a .3DM file. If you still don't see it you can add it in like this:
[3DM]
Version=4
Do you need to write a Rhino v4 .3dm file instead of a Rhino v5 .3dm file?
28 Oct 2020   [#29] In reply to [#28]
Very good job.
Thank you very much.
Rudl
29 Oct 2020   [#30] In reply to [#28]
I've saved the .3DM file and the setting is visible now.
Not now, but I cooperate with others on projects across several CAD platforms and versions, therefore it's good to know, that it's pssibility to save .3DM file into older Rhino version.
I've noticed as well, that MOI can read Rhino5 file and older, do you plan readibility of Rhino6 .3DM files too?
Mik
29 Oct 2020   [#31] In reply to [#30]
Hi Mik,
Not for MoI version 4 but maybe in the future. I'm not sure though, there has been a lot of changes in the OpenNURBS 3DM library for Rhino v6 and it may take a fair amount of work to update to it. I won't really know how much work is involved until I can dig into it some.
I don't really like how it has ended up with new .3dm file versions not being backwards compatible to be readable by older versions of the library.
29 Oct 2020   [#32] In reply to [#1]
Once again, excellent work has been done. Thanks a lot, Michael
-Moritz
29 Oct 2020   [#33]
Good work.
Looking forward to finally paying for this upgrade - you've earned it.
Perhaps you can now take a break and relax for awhile.
Then we can talk about version 5. :)
Frederick
29 Oct 2020   [#34] In reply to [#31]
Yes, that is problem in mainstream sw in general as well as Rhino.
http://docs.mcneel.com/rhino/5/help/en-us/fileio/rhino_3dm_export_to_earlier_versions.htm
Fortunately it exists certain transfer files.
BTW. I had chance to compare Rhino vs MOI soem days ago, and I have to say the intuitiveness and effectiveness of MOI is very addictive :-). Thanks for such great sw.
29 Oct 2020   [#35] In reply to [#18]
> There is actually an "Arrow gap" setting for that which doesn't have an
> entry in the UI yet because I have been waiting to see if anyone needed
> it or whether I could get rid of it. The reason why I wanted to get rid of
> it is that it will make some other future options like spline curve leaders
> a lot more difficult with the spline needing to be clipped.
Well in that case, I'd vote for keeping it simple now to ease your future plans. Since I'm just an amateur draftsman, probably worth waiting to see what the professionals think regarding the need for an "Arrow gap".
> If you're generating some PDF output with leaders and/or dims I'd
> love to see some example PDF files!
Attached. While Max's script has been greatly appreciated, your new dimensions tools are a treat to work with and I really like being able to see the Text and Value fields in this new beta. In this case some simple plans for an addition.
--Larry
Floorplan.pdf
Roof plan.pdf
29 Oct 2020   [#36] In reply to [#35]
pls find attached PDF export examples.
It works perfectly!
Dim Test.pdf was exported via your excellent Make2D4Views script, Dim Test2 was exported from copied models and arranged into same views as via script.
When I exported Dim Test.pdf the dialog window didn't offer Line styl option as in case of export directy from arranged 3D models.
It woud be great to have Line style option for export lines only or new script "ArrangeModelInto4Views" :-)
Is it possible to avoid the "corner line" in angular dim?
Mik
Dim Test 2.pdf
Dim Test.pdf
29 Oct 2020   [#37] In reply to [#36]
Probably new script "ArrangeModelInto4Views" woud be more useful for possibility of shaded backround.
Mik
Dim Test 3.pdf
29 Oct 2020   [#38] In reply to [#37]
I have one more question.
If I export some geometry and uncheck before export "generate hidden lines", then dialog window appears "Generating hidden lines" and some time it takes generating hiddens lines probably, but they are invisible in exported geometry.
No problem with simple model, but it takes significant amount of time when it's exported complex model.
Is it such behavior correct?
Mik
29 Oct 2020   [#39]
Does it possible to have Dimensions "Front Camera" in the 3D View?
Like here in SketchUp
29 Oct 2020   [#40] In reply to [#39]
I think that yes, after clicking on the annotation details it has to be chosen in Annotation properties/Display/Screen aligned.
Mik
29 Oct 2020   [#41] In reply to [#39]
Hi Pilou, yup like Mik writes above that's available with this setting:
If you want to set it on an individual dimension you can do that by selecting it and using the "Details..." button to get to the Object properties dialog shown above.
If you want it to be the default behavior for newly drawn ones then set it in the preset properties under Options > Dimensions.
