Show messages: All
1-9
10-15
Updated! I think I have fixed the issue, although the solution was counter-intuitive. Deleting Moi3d v4 from the accessibility list in security seems to have fixed the issue, no more extrusion lag.
Colin
Hi Colin, hmm can you try going into Activity Monitor and then highlight "MoI v4 beta" in the processes list and on the wheel button in the toolbar pick "Sample Process" and maybe try to move the mouse around in an Extrude while it is sampling for the next few seconds and then send the report to me at
moi@moi3d.com ?
Also another one is in Activity Montior note the pid for the "MoI v4 beta" process and from a Terminal prompt do:
kill -s SIGSEGV pid_number_here
That should trigger a crash dump to be generated, it may take it a minute or so before it shows up in the finder window that pops up. If you can generate that and also send it to me maybe I will be able to see something in there.
(hadn't seen your newer msg when writing this...)
Thanks, - Michael
That's great Colin, I wonder what side effect that accessibility list has that makes it slower? I'll try to see if I can find out anything about that.
I can repeat over here that putting MoI on the "Security & Privacy" > Privacy > Accessibility > "Allow the apps below to control your computer." list causes lag.
I'll poke around a bit to see if I can figure out why - maybe it's a slowdown in spawning a worker process moreso than inter-process communication. But also I don't think that it is needed to grant MoI special permissions like that anyway though.
Hi Colin, also do you happen to remember why Moi got added into that list? Does the OS tell you to put it there if you try to save into certain folders or something like that?
Hi Michael, I'm sorry I don't recall adding it, but I doubt I would have added it without being prompted to do so. Moi3d V3 is also on that list as well.
Colin
Show messages: All
1-9
10-15
