Full Version: Moi <> Blender !
Show messages:  1-19  20-39  40-59  60-68
13 Oct   [#60] In reply to [#59]
Hi Carlos, so go to c:\Users\<username>\AppData\Roaming\Moi\startup and there should be a file there named "97 BMoi.js", replace it with the one attached here.
This one has the "exact" parameter added in to the import button's command.
Does that work?
97 BMoi.js
13 Oct   [#61]
Yes, its working! Thanks a lot, Michael.
15 Oct   [#62] In reply to [#56]
It works. Thanks!
I leave here a link to updated OD_copypaste script for Zbrush that will work fine with newer Zbrush versions. For users that would like to use Moi3D and Zbrush connection. The script is in comments below.
https://www.zbrushcentral.com/t/useful-tool-to-copy-and-paste-geometry-between-zbrush-and-other-3d-editors/408590
15 Oct   [#63] In reply to [#60]
Hey, that's useful, thanks Michael!
15 Oct   [#64]
Hi Michael, will it work on a Mac Intel? Thanks.
15 Oct   [#65] In reply to [#64]
Hi Carlos,
Are you asking about this one you linked earlier? :
https://github.com/Flowgun/BMOI_Connector/tree/master
It looks like it's all done with script so I think it should work on Mac as well. But looks like there aren't any install instructions for Mac.
On Mac the MOI appdata folder is located at ~/Library/Application Support/Moi
15 Oct   [#66]
Yes, its working nicely. Thank you so much.
15 Oct   [#67]
This script will save me time in my workflow, maybe a couple of hours per month.
Thanks to everyone involved: Michael, TitusLVR, Flowgun and Max Smirnov.
Agree with Nameless about "export curves from MoI and turn them into bezier curves in Blender".
Carlos
25 Oct   [#68]
