Full Version: Extrude Function request
Show messages: All  1-8  9-10
19 Aug 2020   [#9] In reply to [#8]
Hi James,
> Is there a scripting method to extend cap end options to include single end only.
There isn't one directly built into the extrude factory itself but it's possible to make that by extruding with no caps, then using PlanarSrf to build a single cap, transform it by moving it in the extrude direction, then joining the cap with the extrusion.
19 Aug 2020   [#10] In reply to [#9]
Thanks Michael,
"extruding with no caps, then using PlanarSrf to build a single cap, transform it by moving it in the extrude direction, then joining the cap with the extrusion."
I am familiar with this approach, although the method of extruding with caps on, then selecting & deleting the base face is a generally less awkward.
It is surprising to me that this feature request is not more common, even if the work around is pretty straightforward.
Thanks again,
