Full Version: Selecting Objects
Show messages:  1-7  8-27  28-34
4 Aug 2020   [#28] In reply to [#27]
Thanks WN. In Michael's video he drags a box and it only selects the surface. If I drag a box it seems to select the surface and edges. Why?
Update - OK I see I have to go to Types -> Curves and hide them first...
Andy
4 Aug 2020   [#29] In reply to [#28]
Hi Andy, yes curves can also be used as a cutting object which cut all the way through an object. So with those selected you had multiple cutting objects.
V4 will be a free upgrade if you've ordered V3 within the past 1.5 years or so, or $100 if you ordered V3 before that.
4 Aug 2020   [#30] In reply to [#28]
I've attached a video, take a look.
I hope it helps.
Karen.mp4
4 Aug 2020   [#31]
WN - thanks for the video - it helps.
Michael - ah ok. I ordered Aug 1st 2018 so just a bit too long.
Andy
4 Aug 2020   [#32] In reply to [#31]
Hi Andy, I haven't determined the exact cutoff date for the free upgrade yet. It will be at least Sep 2018 so yes you might end up just barely outside it.
4 Aug 2020   [#33] In reply to [#32]
Bummer.
Andy
Message 9906.34 was deleted
