Full Version: Layer Styles?
Show messages: All  1-5  6-10
5 Sep 2020   [#6] In reply to [#5]
Example graphic used where 'all layers' or all pdf pages are merged.
1. Single file import..
Single file import just takes an .eps dxf or .ai file and 'pastes' into moi3d and creates
the layer name and style.
2. Multi file import would create 4 MOI3D' layers'
File #1
File #2
File #3
File #4
.eps files attached in this example.
3. Multi page pdf.
Moi imports the pdf its 3 page numbers or 3 bookmarks in this example
each page is effectively seen as a seperate layer/object group and on top of each other.
Moi creates the layer/style/object names.
Note: At moment moi seems to be able to import multi page PDF documents
- but all on one drawing area.
1-TO-MOI-1.eps
2-TO-MOI-2.eps
3-TO-MOI-3.eps
4-TO-MOI-ALL-OBJECTS.eps
MOI3D_#2_import-multiple-files-to-STYLES-or-object-layers.3dm
PDF-LAYERS-TO-MOI.pdf
all-layers-or-pages-ON.jpg  MoI-file-name-to-styles.jpg  PDF-PAGES-TO-MOI-BOOKMARKS-AS-LAYER-NAME.jpg
5 Sep 2020   [#7] In reply to [#5]
Hi Stefano,
> Re: dxf very interested to see the v4 final or dialogue or at least a demo of that. I wont be in trial mode soon ;0)
If you have an example DXF file where you wanted layers to come through, if you can post it I can convert it and post the result back and then you can see what that looks like.
re: file import to style with filename, try the attached plug-in.
ImportFilenameToStyle.js
5 Sep 2020   [#8] In reply to [#7]
Many thanks for this Michael, I anticipate to have the license on
Monday just deciding which reseller.. best I try dxf bit later. I think I've seen enough and want to move forward now.. really like flexibility the software can provide and excited to get things done to my ideas...
FYI:
My intention is to develop a very fast workflow for creating models all basically same product, mainly just with dimension changes... then export and render these fast...
One question, very relevant to this potential workflow is...
Can a dxf or vector object that's been imported be identified easily by line weight, object name or some other feature like colour or the 'style layer' it's on?
Basically I would create a load of points, dots or shapes
and want these individual 'reference objects' to be replaced with a moi3d library object, in a click.
You can presume these objects will start as 2D or have ZO
until moi takes over :0)
Kindest Regards
Stefano
5 Sep 2020   [#9] In reply to [#8]
Hi Stefano,
> Can a dxf object that's been imported be identified easily by line weight or some other feature
Currently MoI does not have any support for assigning line weights, and colors cannot be set as an individual object property. An object's color in Moi comes from the style that it is assigned to.
But I would think the style/layer that its on could be used for that.
But I'm not sure that I entirely understand what you're trying to do by identifying the imported object.
5 Sep 2020   [#10] In reply to [#9]
Hi Michael, I feel that's great for now. Will 'get stuck in' learning moi3d (v4 etc) next. Probably best to create a seperate post with an example on my particular object 'swapping' idea bit later. Thanks again for your
answers that have created positive momentum.
-- Stefano
