Full Version: Ship hull tutorials
Show messages:  1-3  …  64-83  84-103  104-123  124-129
12 Jun 2020   [#124] In reply to [#123]
OK, thanks. I moved it away from the little parts as it worked. However, on another part, when I boolean, it suddenly deletes the structure for some reason! What happened?
I slowly learn!
G
12 Jun 2020   [#125] In reply to [#124]
Hi Gord,
If you post the model I can take a look. It's hard to guess what might be going on without the model.
But it's probably related to those problem spots with micro faces and edges that don't connect to each other very accurately like I was talking about above.
13 Jun 2020   [#126] In reply to [#125]
Could be that, if that happens. I've redesigned that bit now and put the rails on if a slightly different place. All a solid!
G
13 Jun 2020   [#127]
Minutes 14.00 and following..
Minutes 2.30 and following
Minutes 7 and following
31 Jul 2020   [#128]
Polycad if free! ;)
http://www.polycad.co.uk/ Import Export IGES so entierely Moi3D compatible! ;)
https://moiscript.weebly.com/polycad.html French version of the site ;)
Just a part of an huge prog!
21 Nov 2020   [#129]
They are progressing!
