Full Version: Modeling help
Show messages:  1-11  12-31  32-38
30 Jun 2020   [#32] In reply to [#31]
Thanks for the comments Michael. It seems that I have made small errors when editing/mirroring parts so it is good to understand that these are causing the problem. Naturally it is difficult to spot these because the model/parts are huge in size.
5 Oct 2020   [#33]
Again I would like to ask some help in modeling approach. How would you model this kind of shape?
I would need to model a fan duct for a 3D printer and I would like to use this model as a basis. I need to remodel the fan to make it fit to my purposes but how could I create this kind of geometry? I have tried to take some basic planes from the original model and I have tried to use Loft + Shell functionality to create the shape but this doesn't create a solid model but it get splitted. Do you have any ideas how to model this kind of shape that hollow from inside?
I was also able to import the original model to Moi3D as a obj file but it seems really complicated to edit the obj imported model. This is the reason why I was planning to model it with the help of some basic planes from the original model.
ChironFan.3dm
5 Oct 2020   [#34] In reply to [#33]
Short extruded, rectangles, or circles or ovals can be blended between. Select the edges to blend, not curves.
Delete or hide, the curves overlying the edges.
-Brian
The short extrusions can be temporary.
The blended sections can also be blended between.
Make some strategically placed cross sections...Small extrude, Blend, (delete unwanted extrusions), Blend remainder, repeat ...
5 Oct 2020   [#35] In reply to [#33]
this may help.
1)Create temporary lines.
2)Blend between them.
3)Loft straight with close and planar to form solid.
4)Extrude Fan chamber.
5)Boolean union and add fillets if required.
6)Remove Entry and Exit faces.
7)Shell.
Barry
6 Oct 2020   [#36] In reply to [#35]
Thanks a lot for detailed instruction. I had not used Blend command earlier and I was not aware that you can use it also for lines. I am not sure how the Blend selects the position/direction of the blend but I finally got it working!
Loft was also giving me really weird results but I finally used Network + Shell commands I was able to create the needed shape.
6 Oct 2020   [#37] In reply to [#36]
the blend works by which end of the line you click on when you select them.
The loft works in the order you pick the curves so that's probably the problem you experienced.
Anyway glad your sorted.
Barry
6 Oct 2020   [#38]
Blend also works on edges. Note that cylinders do not have their ends, and there are no curves at the ends, just the edges.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9222.5
-Brian
