Full Version: Batch filleting
Show messages:  1-19  20-22
13 Feb 2023   [#20]
You can also use something like that! ;)
(some more versatile: works with any forms and without edit any codes :)
BoundingBoxCenterMultiple by Michael Gibson https://moiscript.weebly.com/uploads/3/9/3/8/3938813/boundingboxcentermultiple.zip
Can be used to simulate a replacement of objects
By coupling it for example with CopyToPoints or Vclone from MaxSMirnov
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
https://moiscript.weebly.com/burman.html (all scripts and commands collected by Burman)
Vclone replaces the vector by the object with size and orientation of the vector!!!
Following with BoundingBoxCenterMultiple & CopyToPoints
Of course a Circle can be used against here a Cylinder! ;)
15 Mar 2025   [#21] In reply to [#15]
Hi Michael
batcheditcircles脚本在V3中,无论是否选中圆,一直显示该错误。(The batcheditcircles script in V3 consistently displays this error regardless of whether a circle is selected or not.)
能否通过修改使该脚本能在V3中,能够正常使用?(Can the script be modified to work properly in V3?)
15 Mar 2025   [#22] In reply to [#21]
Hi SUIYAN,
The script needs curve properties .isCircle and .conicRadius which were added in V4.
So it requires at least MOI version 4 to run, it would be difficult to make it work in V3, sorry.
