Full Version: Batch filleting
Show messages:  1-14  15-22
11 Feb 2023   [#15] In reply to [#14]
Hi Axel,
> is anybody aware of a batch radius command? That should make changes on the radius/diameter by
> batch on several circles at same time.
I'm not aware of one so I made a new one for you, attached.
Instructions for installing a plug-in here.
BatchEditCircles.zip
12 Feb 2023   [#16] In reply to [#15]
fantastic, what a help.
Thank you!
Best regards, Axel
12 Feb 2023   [#17]
Great script is it possible to add to this select circles by size rad or diameter so if you a group of circles of varying sizes you can select 1 size and change those only.
regards
Alex.
12 Feb 2023   [#18] In reply to [#17]
Hi Alex,
Yes you could modify the script to do that.
Maybe something like this - currently in BatchEditCircles.js on line number 70 it is gathering up the circles, the current code looks like this:
		if ( obj.isCircle )
			circles.addObject( obj );
			var this_radius = obj.conicRadius;
You could modify that to only gather up circles of a particular radius value, add something like this (warning untested) - added lines marked with a > at the start of the line, don't put that in the actual code. Oh and also move the line where it calls addObject lower down:
		if ( obj.isCircle )
>			//circles.addObject( obj );       *moved lower*
>			// Added code here:
>			var target_radius = 5.0;
>			// Don't gather the circle unless it matches the target radius.
>			if ( Math.abs( target_radius - this_radius ) > 1.0e-12 )
>				continue;
12 Feb 2023   [#19]
as always lightning service many thanks Michael Ill have a play.
regards
Alex.
13 Feb 2023   [#20]
You can also use something like that! ;)
(some more versatile: works with any forms and without edit any codes :)
BoundingBoxCenterMultiple by Michael Gibson https://moiscript.weebly.com/uploads/3/9/3/8/3938813/boundingboxcentermultiple.zip
Can be used to simulate a replacement of objects
By coupling it for example with CopyToPoints or Vclone from MaxSMirnov
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
https://moiscript.weebly.com/burman.html (all scripts and commands collected by Burman)
Vclone replaces the vector by the object with size and orientation of the vector!!!
Following with BoundingBoxCenterMultiple & CopyToPoints
Of course a Circle can be used against here a Cylinder! ;)
15 Mar 2025   [#21] In reply to [#15]
Hi Michael
batcheditcircles脚本在V3中,无论是否选中圆,一直显示该错误。(The batcheditcircles script in V3 consistently displays this error regardless of whether a circle is selected or not.)
能否通过修改使该脚本能在V3中,能够正常使用?(Can the script be modified to work properly in V3?)
15 Mar 2025   [#22] In reply to [#21]
Hi SUIYAN,
The script needs curve properties .isCircle and .conicRadius which were added in V4.
So it requires at least MOI version 4 to run, it would be difficult to make it work in V3, sorry.
