Full Version: The Globes and the Dimples
Show messages:  1-19  20-39  40-44
16 May 2011   [#40] In reply to [#39]
Hi karlos, to install the script, you copy the import_moi.py file into Blender's script folder, which by default will be here I think:
C:\Program Files\Blender Foundation\Blender\.blender\scripts
Once that import_moi.py file is in Blender's script folder, the next time you start it up it will have a new entry on its File > Import menu that says "MoI with Normals (.lwo)".
Note that this is for Blender version 2.49 only, the script will not work on the newer Blender 2.5 versions.
17 May 2011   [#41]
Hey
Anthony also made a 2.5 version, which can be located here:
http://chronosphere.home.comcast.net/~chronosphere/true-normals.htm
16 Jan 2020   [#42] In reply to [#41]
Hi All,
Just wondering if there's still a blender importer out there for MoI?
Thanks!
16 Jan 2020   [#43] In reply to [#42]
Import a Blender file inside MOi ?
you can use directly OBJ files with the Max Smirnov _importOBJ or the new native Transform / SubD
You can also use FreeShip to export in IGES format, the "subdivision surfaces" made with Blender.
I believe that Blender has not yet Nurbs Volumes!
16 Jan 2020   [#44] In reply to [#42]
Hi jweber, if you mean importing files made in MoI into Blender, it used to be the case a long time ago that a special importer was needed to have vertex normals come through. But Blender's default .obj file importer has been improved a lot since then so now there is no need to use any special importer, just use .obj format for transferring into Blender.
