19-38
39-44
Hi! please help me...im new at blender and im kinda stupid... where do i put the link you are giving so i can use a MoI3D file into blender...please help me i dont know anything about scripts and i can't seem to find where to put the link you give
Hi karlos, to install the script, you copy the import_moi.py file into Blender's script folder, which by default will be here I think:
C:\Program Files\Blender Foundation\Blender\.blender\scripts
Once that import_moi.py file is in Blender's script folder, the next time you start it up it will have a new entry on its File > Import menu that says "MoI with Normals (.lwo)".
Note that this is for Blender version 2.49 only, the script will not work on the newer Blender 2.5 versions.
Hey
Anthony also made a 2.5 version, which can be located here:
http://chronosphere.home.comcast.net/~chronosphere/true-normals.htm
Hi All,
Just wondering if there's still a blender importer out there for MoI?
Thanks!
Import a Blender file inside MOi ?
you can use directly OBJ files with the Max Smirnov _importOBJ or the new native Transform / SubD
You can also use FreeShip to export in IGES format, the "subdivision surfaces" made with Blender.
I believe that Blender has not yet Nurbs Volumes!
Hi jweber, if you mean importing files made in MoI into Blender, it used to be the case a long time ago that a special importer was needed to have vertex normals come through. But Blender's default .obj file importer has been improved a lot since then so now there is no need to use any special importer, just use .obj format for transferring into Blender.
19-38
39-44
