Full Version: Line order and direction
Show messages:  1-19  20-22
16 Sep 2020   [#20] In reply to [#16]
Hi Wayne, another way you can determine the direction just using 2D points is to make a 2D triangle and then compute the signed area of the triangle:
https://www.quora.com/What-is-the-signed-Area-of-the-triangle?share=1
It will be a positive number for CCW, and a negative number for CW.
17 Sep 2020   [#21] In reply to [#19]
Yes, I am only using the top view plane. The methods you suggested will be looked at in closer detail.
Thank you.
Wayne
12 Sep   [#22]
Here's a small update to the orderCurves plugin that works on curves smaller than 1 unit long.
orderCurves.zip
