5-24
25-44
45-49
That was that ! Bravo!
And the marvelous is that you can move this Floating window to the other monitor!!!
Here Moi is on my Portable Computer, Floating Window on my external Monitor
Of course I can make the inverse because my monitor is some bigger that my portable PC ! :)
Image don't show the true size reality! :D
Curious that was not made before ?
Nice script hl - thank you!
Hi Pilou, I misunderstood your pic at first - I thought you just created for us a beautiful Totem Pole of MoI :)
...but it would make an interesting project for one of our resident artists - 3D printable ideally - with the MoI head to top - any objetions Michael?
Thanks Michael for the tweak to hl's script - I still don't know where you find time to do product dev and reply to so many posts. BTW, we must owe you some money for all the V4 upgrades by now? I'm just getting back into MoI after a long period on other non-CAD projects, but MoI never looses its appeal, thank you!
Hamish
Hi Hamish!
No objections, it sounds like a fun project!
Not yet, there's still one more beta to go with a last set of bug fixes and export for dimensions.
@ HairyKiwi Yes that was also a very pretty totem! :)
Does it possible to have text under the icons ?
Thanks a lot
simply genius !
can be use with FullScreen for people who use 2 screen
sure very cool! ;)
Here the file to put inside folder command and make a shortCut FullScreen or press Tab ad write Fullscreen (Fullscreen, FUllScreen etc)
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=519e833721d1b435aa1f6a2f8590a4b0&filename=FullScreen.js
Strange Thing about using the fullscreen script.
All is right using it 7 or 8 times then, MOI is blocked ?
Is it mine version or a general problem ?
I use beta 4.0 01/22
In this particular version hl has removed all the text so you would need to add it back, the text content goes inside the moi:CommandButton elements, like where the TEXT is shown here: <moi:CommandButton>TEXT</moi:CommandButton>
Hi Phiro,
Can you give a little more detail about what you mean by "blocked" ? Are you able to move viewports and the screen redraws or is it totally frozen ?
The application is totally frozen.
Viewports don't move.
I must use the process manager to kill it.
Each time I call the script the process use 10Mb more memory.
When I launch MOI, process uses about 60Mb. After using the script 7 or 8 times, the process use 150Mb and is frozen.
OK :) I have changed display:none;..........in display:yes;....not sure that must be that but that works :)
<style>
/* Turn off text block under command button icon */
moi\:CommandButton > div {
display:yes;
</style>
Another thing here the French translation but how to make the English for be call in Options ?
Possible or not : so 2 versions that i enable or not manually ?
Hi Phiro,
The most likely thing is a video driver bug which is triggered by the viewport resizing.
First thing to check would be to get the latest video driver from the manufacturer's web site and see if that solves it.
It's possible to do this using <moi:Text> elements instead of hard coded text.
A <moi:Text> element will look up text from the string table of the current active language.
So for example with the first one you would put <moi:Text textid="Line"> in the text location.
That will then look up the entry with a left-side value of Line= inside the current Strings.txt string table, so that would come from EnglishStrings.txt if the current language is English, or FrenchStrings.txt if the current language is French.
Absolutly perfect!
| <moi:CommandButton icon="moi://ui/icons/LineIcon.png" command="line"><moi:Text textid="Line">Ligne</moi:CommandButton> |
Hum hum :) (for beta 4)
Icon for pipe works fine (personal icon ;)
But text not so good...
I try to make the first line (10 icons)... French /English but not total success! :)
Some stay empty!
I don't believe i had made some type errors ???
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/sidepane1.htm
I forgot an icon. It's made by myself
Pipe.htm
Pipe.js
Almost - it would be good to put a "self-closing" slash on the <moi:Text> and since it will supply the text you don't want any additional text in there.
So you would want it like this:
<moi:CommandButton icon="moi://ui/icons/LineIcon.png" command="line"><moi:Text textid="Line" /></moi:CommandButton>
Thank you Michael
> Some stay empty!
There's a few things - it would be good to have a close tag on the <moi:Text> elements, that could be either <moi:Text textid=""></moi:Text> or a shortcut way is <moi:Text textid=""/>
Also since the <moi:Text> element will have text inserted inside it, you don't want additional text in there next to it, it probably happened to work because with the missing close tag your extra text was a child of the <moi:Text> and got replaced when it inserted its looked-up text content.
Last thing is the textid="" attribute must exactly match a name in the Strings.txt file including upper/lower case. So for example you have textid="PolyLine" but the name of that entry in the strings.txt files is actually Polyline= . Because you have different capitalization it won't find it.
So for polyline you would want this:
<td><moi:CommandButton icon="icons/PolylineIcon.png" command="polyline"><moi:Text textid="Polyline"/></moi:CommandButton></td>
5-24
25-44
45-49
