Full Version: Surfaces not tangent or separated
Show messages:  1-9  10-29  30-43
22 Mar 2020   [#10] In reply to [#8]
<< SUBD can help in this situation?
No in optic "already know where you want to go" for have a precision wanted...
as it's always a surprise when you press the SUubDivide button ! ;)
Maybe trim volums Fillets then boolean ... a workflow is to find...
22 Mar 2020   [#11] In reply to [#10]
Really?
I'll try my right workflow!
Marco
22 Mar 2020   [#12] In reply to [#9]
Hi Marco,
> From what I can see, a command to extend surfaces is missing, am I right?
It is but the method using Flow that I showed above can be used to accomplish it.
22 Mar 2020   [#13] In reply to [#11]
Personal workflow when you find it is always the best for you! :)
22 Mar 2020   [#14] In reply to [#12]
Ok, Michael...
Good!
22 Mar 2020   [#15] In reply to [#13]
Hope so!
I've to learn tons of commands and their uses.
Bye
22 Mar 2020   [#16] In reply to [#15]
Subdiv is maybe not for your case ;)
But can be useful for imagine creative forms!
there are for the moment only 5 principal functions ;)
Native Extrude + special SBridge, SsPlit,Sscale, Subdive
as you see fillet is special ;) And you can't made fillet on the "edges" of a volume subdivided!
22 Mar 2020   [#17] In reply to [#16]
Yes, exactly what I mean!
Usually, in Rhino, I draw a circle with the given diameter and then create a form; moving some points I try to achieve the model I need and use the circle as reference. So I try to be nearest to the circle, it doesn't matter of the precision, because when the ring is casted and polished it change its dimensions.
The important things are the setting for the stone that must be precise... but I can use nurbs with standard commands.
So, yes... it's good as you wrote!
I think that, starting from a cube, I can add faces following the guide circle to form a ring... right?
Marco
22 Mar 2020   [#18] In reply to [#16]
Hi Pilou, first af all big thanks for your fantastic input, much appreciated !
One question: what do you mean by "special SBridge", is this different from
this version:http://moi.maxsm.net/files/scripts/sBridge.v.0.71.2015.03.26.zip
Thanks again + best wishes !
23 Mar 2020   [#19] In reply to [#18]
sBridge (plugin) is "special" function for Subdivision against "native" Extrude who can be used in certains faces for subdivision! ;)
Yes it's the Max Smirnov one! ;)
23 Mar 2020   [#20] In reply to [#19]
Many Thanks !
23 Mar 2020   [#21] In reply to [#1]
Hi Marco,
not sure if this is the result your looking for but this was produced by using half of the helix (outer diameter of ring).
I extruding it to max depth then trimmed as Michael as shown.
I then shelled it and filleted.
It was necessary to trim the solid where it was going to join in the middle as this was not flat due to the shelling.
I then copied the half revolved it 180 and joined.
Hope this helps.
Barry
23 Mar 2020   [#22] In reply to [#21]
Barry!!!
That is exactly what I expected to achieve!!!!!!
Thanks a lot
24 Mar 2020   [#23] In reply to [#22]
Barry,
I follow Michael advises and yours, but... how did you solve the issue in the point where it has to be join?
Mhhh...
In all this job, a profile is missing I think!
Thanks a lot!
Marco
24 Mar 2020   [#24] In reply to [#23]
Hi Marco,
did you use the shell command (see photo's).
There is no need for a profile.
Make sure to do the filleting on just the half as I had problem trying to fillet after joining.
Barry
24 Mar 2020   [#25] In reply to [#24]
Yes,
exactly Barry... that face is not squared and it's rotated, so when I copy-rotate the solid, the result is what I've attahced to my post before...
I can't figure out how to solve...
I followed the same yours steps!
Marco
24 Mar 2020   [#26] In reply to [#25]
Hi Marco,
it looks like you have extruded the half helix square to the angle of the helix and it should be square to the axis.
If this isn't the case please send me your file.
Barry
25 Mar 2020   [#27] In reply to [#26]
Ok understood...
Thanks.
What about the fillets, now?
I've cutted and reconstructed the surfaces to avoid crossing points and then launched the fillet... but you can see the results... any idea on how to apply correctly it to the model?
Thanks a lot.
Marco
test.3dm
25 Mar 2020   [#28] In reply to [#27]
Post your file before fillets!
Normallly you must have the same fillet along all the volume (don't accept the fillet if you want the following possibility)
then free to you after to make any new "variable fillets" during the same session of fillet on some edges!
25 Mar 2020   [#29] In reply to [#28]
Pilou... or maybe Frenchy? ;-)
The bottom small fillet is ok... The top one, instead, is just a suface that moi has used as filletting surface, so its another surface! Just delete it and you have the original solid. I left it just to make you know where is the issue.
Here attached you can find the solid without fillet
Thanks.
Marco
test.3dm
