Full Version: Rotate Array?
Show messages: All  1-18  19-20
18 Jun 2024   [#19] In reply to [#18]
Thank you Pilou & Michael, et. al.
I need to be able to run RotateArray more than once upon the same array, so that I can do so from more than one viewport.
I still don't know how to do that.
I can't finish what I need without it.
Please help!
18 Jun 2024   [#20] In reply to [#19]
Hi MindSet,
The result generated by RotateArray can be used in a 2nd run just by running the command again.
Just move your mouse over the other viewport that you want to use for the second application.
Make sure to include a point object with the array, that will be used as the center of rotation.
So for example here's an array prepared for RotateArray:
Select the arrayed objects:
Run RotateArray:
Move mouse over the other viewport, for example here I moved over the "Front" viewport:
Run RotateArray again, this one will rotate in the Front view:
RotateArray1.jpg  RotateArray2.jpg  RotateArray3.jpg  RotateArray4.jpg  RotateArray5.jpg
