Full Version: About SubDivide in nurbs :)
Show messages:  1-17  18-37  38-57  58-77  78-97  98-117  118-137  138-141
21 Feb 2021   [#78]
Searching something for all kill the internal volume (faces, edges) for make some cool subdivided object...
it appears that is very difficult directly in Moi ! (for the moment (?) )...
Boolean union will remove the internal faces but also merge together some of the outer ones.
Edit Join don't remove internal faces!
So no success!
5 boxes for test your scripts or other tricks! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/5boxes.3dm
the 3 little boxes have no internal faces because built with Max sSplit :)
the 2 other have mutual faces!
But i have found some little tricks! :)
- Export as OBJ / Ngon Without Without Weld vertices along Edges!
- Import OBJ from SUbDiv/ Create /From File
- Boolean Union
- Max Subdiv
That works fine...except for this case!
don't works when "cubes" are tangent by a commune vertical edges!
Works in other compact or alone positions!
the bad case (works in other cases! )
so no total success again!...
but i have found another trick for this particular case! :)
Up or down the top face of one of these 2 boxes by a very, very tiny distance!
et voilĂ ! :)
Have fun subD modeling before a script or command OR NODES who kill all internal volume! :)
(second box was made with sBridge by Max Smirnov
22 Feb 2021   [#79]
18 Jun 2021   [#80]
Relaxing in 10 seconds :)
Bonus :)
7 Jul 2021   [#81]
7 Jul 2021   [#82]
PolyLine
Offset
A segment between same vertex of the 2 PolyLines
Sweep
CopyMove Joined Surfaces
Separate
Extrude
Boolean Union
SubDive
7 Jul 2021   [#83] In reply to [#82]
Cool techniques, Pilou!
22 Sep 2021   [#84]
When some faces on a solid are not divided for general SubDivide so fails
Draw lines missing
Select All / Trim
Kill Curves (Browser curves selection)
SubDivide
10 Oct 2021   [#85]
Funny in few seconds...
Else how is not evident (here in Blender but will be the same in other) to make in the rules of art
a submodeling sculpting! :)
17 Oct 2021   [#86] In reply to [#1]
Dear Pilou,
Many thanks for all the tips on SubD modelling and especially for the introduction to SimLabs Composer. The possibilities are endless.
Kind regards,
Philip
21 Jan 2022   [#87]
LineWeb for help to make Box Modeling :)
Draw curves
Rebuild say 10 points
Line Web: Lines or polylines or curves: 10 points (order of selection is important! )
Kill curves
Loft "Lines"
Kill Lines
Select faces : Extrude with "Keep Separate"
Boolean Union
Subdivide
21 Jan 2022   [#88]
And if you save your object in OBJ
You can use the free funny Spline for some cool things in seconds without some efforts! :)
Click on the little object ;)
And of course Zoom, Rotate, Move...
21 Jan 2022   [#89] In reply to [#88]
Respect Pilou for your creative use of MOI !
You always amaze us with new surprises !
22 Jan 2022   [#90]
Not exactly Sudivide but...
General article bout "NGons" https://www.artstation.com/artwork/0n93EV
18 Apr 2022   [#91]
Hello all,
Where can I find Subdiv_classic (not Subdiv_Beta_9).
18 Apr 2022   [#92] In reply to [#91]
on this page ! ;)
In case of problem in high resolution, simply increase the Size drastically like 5000%!
https://moiscript.weebly.com/subdivision.html Sub_Dic Classic : Catmull-Clark algorithm
18 Apr 2022   [#93] In reply to [#92]
it says "There was a problem downloading this attachment. Please try again later."
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d663bac37f6f11f9b09b78314c160289&filename=SubdivClassic.v.0.6.2015.02.22.zip
18 Apr 2022   [#94] In reply to [#93]
Hi Psygorn, I don't know why but Max removed all the scripts that were set as file attachments here in the forum, and his script archive web site is offline as well.
So they are not available at their previous locations.
18 Apr 2022   [#95] In reply to [#94]
Thank you for your reply,
I kind of expected that (Knowing Max's website is offline) However, I am having hope that someone has it and could share it with me.
_Psygorn
18 Apr 2022   [#96] In reply to [#91]
Here is a copy
_SubdivClassic.zip
18 Apr 2022   [#97] In reply to [#96]
Hi Wayne hill,
Thank you :-)
