Full Version: About SubDivide in nurbs :)
Show messages:  1-2  3-22  23-42  43-62  63-82  83-102  103-122  123-141
20 Mar 2020   [#63] In reply to [#62]
Beautiful! (and the tuts are awesome too)
20 Mar 2020   [#64] In reply to [#63]
Thx...try it!
it's a true pleasure to make a speedy form then render it! (mine is the free Simlab Composer Lite ;) Max 1920*1080
And a cool change mind in these darkness confined times!
20 Mar 2020   [#65]
And you will see that Subdivision modeling is different than pure Nurbs because you don't know exactly what will be the result!
It's always a surprise when you press the Subdivision's button who transform boxes in voluptuous surfaces! :)
Maybe more artistic filling against mechanical one! ;)
25 Mar 2020   [#66]
This is an interesting discussion and I want share my experience in this field, I made a few experiment and I understood how modelling suddiv for nurbs conversion with moi3d.
1 Oct 2020   [#67]
A new process in the SudDive Tool Box ;)
Project a curve to a complex volume (yet well working for subdive)
Trim
Kill Curve(s)
Join
that all! :)
PS Extrude can't work because face(s) are not in middle of surfaces!
So Copy Move one face(s) then "Bridge" one to one ! Copy / Move Faces can be Multiple!
3 Oct 2020   [#68]
Always funny easy thing for make improbable objects! :)
5 Oct 2020   [#69]
About SUbDivision in Moi ! We can project an object subdivided (finalized or not) on another for deform it! (here on a Sphere )
5 Oct 2020   [#70]
Flow function can be practical for SUbDIve!
Here a cube was projected on a Sphere...of course as always imagination must be large for predict the result!
10 Oct 2020   [#71]
The cutting line method shown above is significantly slower than cutting from a segment!
But indispensable if you want an oblique cut!
14 Oct 2020   [#72]
Some minutes of the days :)
17 Oct 2020   [#73]
Precision! :)
19 Oct 2020   [#74] In reply to [#73]
You need Max's plugins for this to work correct?
19 Oct 2020   [#75] In reply to [#74]
Yes of course: in this precise case _sBridge by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
who can be also used of course for other thing than Subdivision!
22 Jan 2021   [#76]
Seems last version of Rhino 7 uses intensively the SUbD Method! :)
21 Feb 2021   [#77]
Moi SUbdivided object + texture of the fabulous free Vervette SandBox online
http://www.taron.de/Vervette/sandbox/
21 Feb 2021   [#78]
Searching something for all kill the internal volume (faces, edges) for make some cool subdivided object...
it appears that is very difficult directly in Moi ! (for the moment (?) )...
Boolean union will remove the internal faces but also merge together some of the outer ones.
Edit Join don't remove internal faces!
So no success!
5 boxes for test your scripts or other tricks! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/5boxes.3dm
the 3 little boxes have no internal faces because built with Max sSplit :)
the 2 other have mutual faces!
But i have found some little tricks! :)
- Export as OBJ / Ngon Without Without Weld vertices along Edges!
- Import OBJ from SUbDiv/ Create /From File
- Boolean Union
- Max Subdiv
That works fine...except for this case!
don't works when "cubes" are tangent by a commune vertical edges!
Works in other compact or alone positions!
the bad case (works in other cases! )
so no total success again!...
but i have found another trick for this particular case! :)
Up or down the top face of one of these 2 boxes by a very, very tiny distance!
et voilĂ ! :)
Have fun subD modeling before a script or command OR NODES who kill all internal volume! :)
(second box was made with sBridge by Max Smirnov
22 Feb 2021   [#79]
18 Jun 2021   [#80]
Relaxing in 10 seconds :)
Bonus :)
7 Jul 2021   [#81]
7 Jul 2021   [#82]
PolyLine
Offset
A segment between same vertex of the 2 PolyLines
Sweep
CopyMove Joined Surfaces
Separate
Extrude
Boolean Union
SubDive
