Full Version: About SubDivide in nurbs :)
Show messages:  1-14  15-34  35-54  55-74  75-94  95-114  115-134  135-141
12 Mar 2020   [#55]
Hey Sub-D Master Pilou, thank you so much for sharing your insights !!
12 Mar 2020   [#56]
In case of 2 neighbour (or more) different faces - Will works with the volume's faces extremities! ;)
A possible method (the funny game is to find the more speedy effective one! ;)
- Select & Copy Move the 2 faces
- Delete original (easy because yet selected)
- Select Perimeter (careful to not select the vertical middle edge(s) !!! )
- Extrude WITHOUT Cap Ends!!!
- Join All
- SubDivide
Of course can be multiple if you take the same length of Extrude! ;)
(there is an optic effect of record, extrude goes from faces to piece as post above)
12 Mar 2020   [#57]
And Move Points is always possible!
And of course the Sscale!
13 Mar 2020   [#58]
Just use 2 Steps of subdivision (first plane - Extrusion) then extrude the faces!
I am always amazed by the voluptuous result in no time! :)
15 Mar 2020   [#59]
About history after a Mirror : seems Move & Sscale work ! (object or points)
Psplit, Extrude of face(s), Bridge of 2 faces of Original don't work for the moment!
For make an history of a mirrored object
- Mirror Object Original
- Select mirrored Object
- History Enable Update
- Modify Original! :)
15 Mar 2020   [#60]
Multiply an object by Array for unic pasted volume
- Just kill the 2 "faces jonction extremities"
- Use Array
- Recreate the 2 "faces jonction extremities" of the complete object
- Join All
- SubDivide
19 Mar 2020   [#61]
So smooth ;)
20 Mar 2020   [#62]
Piles - use of Bridge for close volumes!
20 Mar 2020   [#63] In reply to [#62]
Beautiful! (and the tuts are awesome too)
20 Mar 2020   [#64] In reply to [#63]
Thx...try it!
it's a true pleasure to make a speedy form then render it! (mine is the free Simlab Composer Lite ;) Max 1920*1080
And a cool change mind in these darkness confined times!
20 Mar 2020   [#65]
And you will see that Subdivision modeling is different than pure Nurbs because you don't know exactly what will be the result!
It's always a surprise when you press the Subdivision's button who transform boxes in voluptuous surfaces! :)
Maybe more artistic filling against mechanical one! ;)
25 Mar 2020   [#66]
This is an interesting discussion and I want share my experience in this field, I made a few experiment and I understood how modelling suddiv for nurbs conversion with moi3d.
1 Oct 2020   [#67]
A new process in the SudDive Tool Box ;)
Project a curve to a complex volume (yet well working for subdive)
Trim
Kill Curve(s)
Join
that all! :)
PS Extrude can't work because face(s) are not in middle of surfaces!
So Copy Move one face(s) then "Bridge" one to one ! Copy / Move Faces can be Multiple!
3 Oct 2020   [#68]
Always funny easy thing for make improbable objects! :)
5 Oct 2020   [#69]
About SUbDivision in Moi ! We can project an object subdivided (finalized or not) on another for deform it! (here on a Sphere )
5 Oct 2020   [#70]
Flow function can be practical for SUbDIve!
Here a cube was projected on a Sphere...of course as always imagination must be large for predict the result!
10 Oct 2020   [#71]
The cutting line method shown above is significantly slower than cutting from a segment!
But indispensable if you want an oblique cut!
14 Oct 2020   [#72]
Some minutes of the days :)
17 Oct 2020   [#73]
Precision! :)
19 Oct 2020   [#74] In reply to [#73]
You need Max's plugins for this to work correct?
