Full Version: Select objects
Show messages: All  1-2  3-6
20 Jan 2020   [#3] In reply to [#1]
And a couple other ones here:
http://kyticka.webzdarma.cz/3d/moi/#SelectTiny
20 Jan 2020   [#4] In reply to [#2]
thank you for your response :)
I have copied the script and add a short cut, but only curves will be selected.
There are some lines in the code with "curves" :) I need to select objects, no curves. I'm not confirm with scripting.
This script from Petr's MOI page seems to do this :)
script: /* Select objects smaller than the given size */ var size = 1.0; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var bbox = obj.getBoundingBox(); if ( bbox.diagonalLength < size ) obj.selected = true; }
Thanks a lot :)
20 Jan 2020   [#5] In reply to [#3]
Thank you Michael,
this script works fine :)
20 Jan 2020   [#6] In reply to [#4]
Seems you right...
