Full Version: Select objects
Show messages: All  1  2-6
20 Jan 2020   [#2] In reply to [#1]
Change your values as you want! ;)
script: /* Select by length */ var min = 1.0, max = 5.0; var crvs = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < crvs.length; ++i ) { var crv = crvs.item(i); var len = crv.getLength(); if ( len>= min && len <= max ) { crv.selected = true; } }
script: /* select biggest curve */ var curves = moi.geometryDatabase.getObjects().getCurves(); var maxlen = -1; var maxcrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen> maxlen ) { maxlen = thislen; maxcrv = crv; } } if ( maxcrv != null ) maxcrv.selected = true;
script: /* select smallest curve*/ var curves = moi.geometryDatabase.getObjects().getCurves(); var minlen = 1e100; var mincrv = null; for ( var i = 0; i < curves.length; ++i ) { var crv = curves.item(i); if ( crv.hidden || crv.locked ) { continue; } var thislen = crv.getLength(); if ( thislen < minlen ) { minlen = thislen; mincrv = crv; } } if ( mincrv != null ) mincrv.selected = true;
20 Jan 2020   [#3] In reply to [#1]
And a couple other ones here:
http://kyticka.webzdarma.cz/3d/moi/#SelectTiny
20 Jan 2020   [#4] In reply to [#2]
thank you for your response :)
I have copied the script and add a short cut, but only curves will be selected.
There are some lines in the code with "curves" :) I need to select objects, no curves. I'm not confirm with scripting.
This script from Petr's MOI page seems to do this :)
script: /* Select objects smaller than the given size */ var size = 1.0; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); var bbox = obj.getBoundingBox(); if ( bbox.diagonalLength < size ) obj.selected = true; }
Thanks a lot :)
20 Jan 2020   [#5] In reply to [#3]
Thank you Michael,
this script works fine :)
20 Jan 2020   [#6] In reply to [#4]
Seems you right...
