Show messages: All
1-2
3-5
Thnx, I know- But iis is unformated.
Is there a way to create a nice xls-xml-pdf-sheet? Like in Excel? in a very fast way? I like the view in the options ;) - I want sort and print my shortcuts ;)
Seems Notepad++ has this sort of formats(except PDF)
so you can reload to Excel...
Hi Lordfox, you can use Excel for that.
First go to moi.ini and select the entire [Shortcut Keys] section and use Ctrl+C.
Inside Excel select cell A1 and use Ctrl+V to paste in the text.
Now stretch out column A (so it is easier to go to the B column), then go to cell B1 and put in this: =LEFT(A1,FIND("=",A1)-1)
That will extract out the text before the first = sign. Select the cells from B1 downwards to your last row and use Fill > Down. This has now extracted the "Key" part of the shortcut key into its own column.
Now in cell C1 put in this: =RIGHT(A1,LEN(A1)-LEN(B1)-1)
That extracts the "Command" part of the text. Select the cells from C1 downloads to your last row and use Fill > Down.
Now hide Column A and you should have 2 separated columns that you can print out.
Show messages: All
1-2
3-5
