Show messages: All
1-2
3-7
Hi Quaritexa, I've added a moi.filesystem.getDirs() method for the next v4 beta that will do this.
For v3 a method that you could try is doing something like a moi.filesystem.shellExecute( 'cmd.exe', '/C /Q dir c:\\ > c:\\scripts\\filename.txt' ) , that should run the dir command of the shell and output it to a file. Then you would need to parse the file.
I tried
var cd = moi.filesystem.getCommandsDir();
moi.filesystem.shellExecute('cmd.exe', '/c dir /a:d /b /o:n "' + cd + '" > "' + cd + 'dir.tmp"');
But it displays the shell window. How to suppress it?
In your command line the /q option is missing
Perhaps is it the problem
The /c option is use to close the Window but /q avoids the echo
Hi Quaritexa,
A couple of possibilities here:
https://superuser.com/questions/191149/how-to-execute-cmd-exe-silently
Maybe this one:
http://www.joeware.net/freetools/tools/quiet/
Thank you, Michael.
I chose this one:
var pd = moi.filesystem.getProcessDir();
moi.filesystem.shellExecute(pd + 'nircmd', 'exec hide cmd.exe /c dir /a:d /b /o:n '+ cd + '> '+ cd + 'dir.tmp');
Show messages: All
1-2
3-7
