Does the latest version of MOI allow exporting obj or fbx with UV maps?
Having a huge problem trying to texture an exported mesh in Houdini.
Hi shamus, you need to set up UV mapping inside your rendering program. The default uv mapping that MOI exports itself is not directly usable although it can be ok if you perform a "separate UV islands" type operation inside the uv editing function of your rendering program.
It's generally best to generate a new uv mapping by unwrapping inside your rendering program though.
