Full Version: Node Wish List
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  416-425
20 Dec 2019   [#96] In reply to [#95]
It is always the same thing from the beginning : a node system created by Max Smirnov!
Better to load here http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
for have the the last extensions : supported by James
20 Dec 2019   [#97]
Thanks! Is there somewhere any step by step tutorial about using the nodes?
20 Dec 2019   [#98] In reply to [#97]
You have my Repository French / English for example of all native nodes
and quasi all extensions nodes :)
I will make rest the next year!
http://moiscript.weebly.com/biblio-elephant.html
Happy Christmas
and don't miss this true gem following (6.5 $ for the end's year) a pefect gift for children or other people! :)
You will can import inside your MOi Objects saved as OBJ format!!!
20 Dec 2019   [#99]
Ok Pilou will look at your repository. And... merry Christmas to you too! Merry Christmas to all people here! : - )
29 Dec 2019   [#100]
Updated ImgSampler node.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Now able to have more than one ImgSampler nodes on a form. Added point array to output.
Wayne
30 Dec 2019   [#101] In reply to [#100]
A-W-E-S-O-M-E !!!
1 Jan 2020   [#102] In reply to [#101]
Happy New Year Everyone,
Here's another proposal for a new node:
Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation : http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
Here is interest blog post on Perlin Noise in JavaScript
http://asserttrue.blogspot.com/2011/12/perlin-noise-in-javascript_31.html
An online 2D peril noise generator
http://www.kitfox.com/projects/perlinNoiseMaker/index.html
Message 9581.103 was deleted
1 Jan 2020   [#104] In reply to [#102]
I believe that this new year about Elephant will be some laborious for me! :)
Happy new year!
PS some ideas of nodes! (look this free prog: JsPlacement) https://windmillart.net/?p=jsplacement
7 Jan 2020   [#105]
New Perlin Noise Node release
This node uses Ken Perlin's routine for generating PerlinNoise(c) data points.
Copy the PerlinNoise.js and perlinnoisefn.js function to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
I would like to thanks James for helping out with testing.
Wayne
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.102
Updated node. Jan 9 2020
9 Jan 2020   [#106]
Hi All,
Just putting up a NODE wish using the new image sampler would it be possible to create a node that can generate this sort of image based on input lines like supplied. Using MAX's FATLINES to create variable width lines based on those 2 variables linework overlaid by image.
Thanks Alex
9 Jan 2020   [#107] In reply to [#106]
FatLines Node
The proposed node would be analogous to Max's Fatlines script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
10 Jan 2020   [#108]
Since there is an elevated interest in voronoi3d at the moment,
http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.177
I thought it would be worth adding it to the wishlist.
Voronoi3d Node
Message 9581.109 was deleted
19 Jan 2020   [#110]
Updated ImgSampler
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Wayne
19 Jan 2020   [#111]
Max Smirnov's Voronoi for the Node Editor
Based on his Voronoi script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
Save voronoi.js file to this directory:
Wayne
19 Jan 2020   [#112] In reply to [#111]
Excellent and all ready made for the Repository! Bravo!
Hyper cool!
23 Jan 2020   [#113]
Does the ImageSampler has limitations ?
Format JPG, PNG ...?
Colors, Grey Levels, B&W, ...?
Size x,y ?
Does it possible to put a Version's Number of Extension, or a date...?
Because it's a mess for know what is the last one! :)
in the title for example (Titre = Title Fr / Eng ;)
I don't see PerlinNoise, PerlinNoiseFn ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.105
...in the Updated NodeEditor ?
23 Jan 2020   [#114]
RoundCrns Node
This is quite self-explanatory: the proposed node would apply rounding to corners of closed polylines/n-gons. (if it also worked on open polylines, that would be a bonus) This is different to "DelCorners" script as these corners would have a user determined radius.
I often use 2 x Construct2/offset nodes in sequence to achieve this result by offsetting inwards then offsetting outwards with "rounded" mode. Although this is mostly a workable solution it fails with small shapes and is not multiprocessing.
A great weekend to all
23 Jan 2020   [#115] In reply to [#113]
The ImgSampler is limited by the processing time and memory it takes to make really large images.
It works with JPG, BMP, PNG, GIF and possibly other formats not tested.
All image colors are converted to grayscale during the processing. Size capacity was not tested. It is capable of very large renderings and will take time and memory to process them.
The latest version has the Crvs output and the image size below. Version numbering would be a good idea because of all the update improvements and more in the future.
PerlinNoiseFn is the function library for PerlinNoise. It does not show in the menu.
Wayne
