Full Version: Node Wish List
Show messages:  1-7  …  28-47  48-67  68-87  88-107  108-127  128-147  148-167  …  408-425
17 Dec 2019   [#88]
Max Smirnov's Subdivide Classic for the Node Editor.
Based on his SubDivClassic script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.164
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.4
Save SubDivClassic.js file to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Wayne
17 Dec 2019   [#89]
What a task!
17 Dec 2019   [#90] In reply to [#89]
It was not that difficult. The code was already proven out by Max. All that was needed was to plugin the node variables along with a few MOI commands to avoid a nesting shell when subdividing an existing object. Other than that, it was easy... (Not really. I had trouble with it... :)
Wayne
17 Dec 2019   [#91] In reply to [#90]
Hello everyone.
But...I was wondering...Has anyone heard from Max Smirnov?
Is he alive?
17 Dec 2019   [#92] In reply to [#91]
Hi Marco! :)
I'm OK :)) I read this forum from time to time ;)
Message 9581.93 was deleted
18 Dec 2019   [#94] In reply to [#92]
Hello Max! :)
But...wait a minute...please...prove me that you aren't a robot.
20 Dec 2019   [#95]
I am coming to the forum after a long time, it is quite possible that I may have missed some episodes and, so, I have to ask: this 'Elephant' thing is something different from the already known nodes plugin or is it the same thing with a changed name?
20 Dec 2019   [#96] In reply to [#95]
It is always the same thing from the beginning : a node system created by Max Smirnov!
Better to load here http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
for have the the last extensions : supported by James
20 Dec 2019   [#97]
Thanks! Is there somewhere any step by step tutorial about using the nodes?
20 Dec 2019   [#98] In reply to [#97]
You have my Repository French / English for example of all native nodes
and quasi all extensions nodes :)
I will make rest the next year!
http://moiscript.weebly.com/biblio-elephant.html
Happy Christmas
and don't miss this true gem following (6.5 $ for the end's year) a pefect gift for children or other people! :)
You will can import inside your MOi Objects saved as OBJ format!!!
20 Dec 2019   [#99]
Ok Pilou will look at your repository. And... merry Christmas to you too! Merry Christmas to all people here! : - )
29 Dec 2019   [#100]
Updated ImgSampler node.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Now able to have more than one ImgSampler nodes on a form. Added point array to output.
Wayne
30 Dec 2019   [#101] In reply to [#100]
A-W-E-S-O-M-E !!!
1 Jan 2020   [#102] In reply to [#101]
Happy New Year Everyone,
Here's another proposal for a new node:
Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation : http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
Here is interest blog post on Perlin Noise in JavaScript
http://asserttrue.blogspot.com/2011/12/perlin-noise-in-javascript_31.html
An online 2D peril noise generator
http://www.kitfox.com/projects/perlinNoiseMaker/index.html
Message 9581.103 was deleted
1 Jan 2020   [#104] In reply to [#102]
I believe that this new year about Elephant will be some laborious for me! :)
Happy new year!
PS some ideas of nodes! (look this free prog: JsPlacement) https://windmillart.net/?p=jsplacement
7 Jan 2020   [#105]
New Perlin Noise Node release
This node uses Ken Perlin's routine for generating PerlinNoise(c) data points.
Copy the PerlinNoise.js and perlinnoisefn.js function to this directory:
I would like to thanks James for helping out with testing.
Wayne
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.102
Updated node. Jan 9 2020
9 Jan 2020   [#106]
Hi All,
Just putting up a NODE wish using the new image sampler would it be possible to create a node that can generate this sort of image based on input lines like supplied. Using MAX's FATLINES to create variable width lines based on those 2 variables linework overlaid by image.
Thanks Alex
9 Jan 2020   [#107] In reply to [#106]
FatLines Node
The proposed node would be analogous to Max's Fatlines script:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
