 26-45
 46-65
 66-85
 86-105
 106-125
 126-145
 146-165
Very nice Stefan :)
Thank you Marco.
Max Smirnov's Subdivide Classic for the Node Editor.
Based on his SubDivClassic script located at:
http://moi.maxsm.net/files/scripts/
Moi discussion reference:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.164
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.4
Save SubDivClassic.js file to this directory:
C:\Users\<UserName>\AppData\Roaming\Moi\nodeeditor\nodes\extensions
Wayne
What a task!
It was not that difficult.  The code was already proven out by Max.  All that was needed was to plugin the node variables along with a few MOI commands to avoid a nesting shell when subdividing an existing object.  Other than that, it was easy...  (Not really.  I had trouble with it... :)
Wayne
Hello everyone.
But...I was wondering...Has anyone heard from Max Smirnov?
Is he alive?
Hi Marco! :)
I'm OK :)) I read this forum from time to time ;)
Message 9581.93 was deleted
Hello Max! :)
But...wait a minute...please...prove me that you aren't a robot.
I am coming to the forum after a long time, it is quite possible that I may have missed some episodes and, so, I have to ask: this 'Elephant' thing is something different from the already known nodes plugin or is it the same thing with a changed name?
It is always the same thing from the beginning : a node system created by Max Smirnov!
Better to load here
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
for have the the last extensions : supported by James
Thanks! Is there somewhere any step by step tutorial about using the nodes?
You have my Repository French / English for example of all native nodes
and quasi all extensions nodes :)
I will make rest the next year!
http://moiscript.weebly.com/biblio-elephant.html
Happy Christmas
and don't miss this true gem following (6.5 $ for the end's year) a pefect gift for children or other people! :)
VIDEO
You will can import inside your MOi Objects saved as OBJ format!!!
Ok Pilou will look at your repository. And... merry Christmas to you too! Merry Christmas to all people here! : - )
Updated ImgSampler node.
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57
Now able to have more than one ImgSampler nodes on a form.  Added  point array to output.
Wayne
A-W-E-S-O-M-E !!!
Happy New Year Everyone,
Here's another proposal for a new node:
 Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation :
http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields  could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
Here is interest blog post on Perlin Noise in JavaScript
http://asserttrue.blogspot.com/2011/12/perlin-noise-in-javascript_31.html
An online 2D peril noise generator
http://www.kitfox.com/projects/perlinNoiseMaker/index.html
https://www.instagram.com/nodeology/ Image Attachments:
Message 9581.103 was deleted
I believe that this new year about Elephant will be some laborious for me! :)
Happy new year!
PS some ideas of nodes! (look this free prog: JsPlacement)
https://windmillart.net/?p=jsplacement
New Perlin Noise Node release
This node uses Ken Perlin's routine for generating PerlinNoise(c) data points.
Copy the PerlinNoise.js and perlinnoisefn.js function to this directory:
I would like to thanks James for helping out with testing.
Wayne
Ref:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.102
Updated node.  Jan 9 2020
 26-45
 46-65
 66-85
 86-105
 106-125
 126-145
 146-165
