Thank you Michael! It was a lot of fun to do this, because of MoI's easy of use and precision,
when it comes to modeling! I will also, at a later date, 3D print this little guy.
It was not that difficult. The code was already proven out by Max. All that was needed was to plugin the node variables along with a few MOI commands to avoid a nesting shell when subdividing an existing object. Other than that, it was easy... (Not really. I had trouble with it... :)
I am coming to the forum after a long time, it is quite possible that I may have missed some episodes and, so, I have to ask: this 'Elephant' thing is something different from the already known nodes plugin or is it the same thing with a changed name?
Here's another proposal for a new node: Noise Generator Node
There are lots of applications for a 2D Perlin Noise fields for natural forms;
for example ocean wave simulation : http://www.alexlorman.com/oceanwavesimulation
Also it would be useful for random transformation the transition smoothly.
Of course 2D Noise fields could be imported as images into ImgSampler, however if they could be generated in NE
there would allow greater control and possibility of animation
